I have a Cat143h motor grader that keeps blowing the front seal out of the All Wheel Drive Pump and blowing hydraulic fluid into the engine. I have ran through the flushing and cooling control valve testing sequence; by testing the charge pressure sequence valve it tested at 400 psi it is supposed to be 435 +/- 10 psi; I also tested the purge pressure sequence valve it is at 300 psi and is supposed to be 290 +/- 10 psi (so I know it is within spec but closer to being out of range than not). I also removed the inline hydraulic filter and found pieces of aluminum inside. I would imagine their is a relief valve somewhere in the system but I don’t have access to it. Can someone please help direct me in the right direction?
