Caseih 5130 PTO problems
Discussion in 'Agricultural Equipment' started by wsw, Dec 18, 2011.
  1. wsw
    wsw Well-Known Member
    Jan 27, 2011
    122
    ontario Canada
    I have a customer with a Case ih 5130 Maxum and they told me the PTO just suddenly stopped, I am mostly heavy equipment repair but this is a good customer and I will be going out to look at it as soon as I am done with the current job. Any advise ?
  2. Richardjw~
    Richardjw~ Senior Member
    Apr 14, 2007
    318
    South Devon, U.K.
    check to see if the linkages are still attached, make sure the 540/1000 selector is engaging.
    The PTO circuit runs about 280psi and is common to the transmission, diff-lock and MFD, if there's a major leak these will also be affected
  3. wsw
    Jan 27, 2011
    122
    ontario Canada
    I have not been there yet but they say this tractor you spin the shaft around for 1000 from 540 PTO speed
  4. Iron@Dirt
    Iron@Dirt Senior Member
    Aug 27, 2010
    305
    south lou.
    There is a sliding collar in the housing that shifts gears with the different end of the shaft, known for giving trouble.
  5. wsw
    Jan 27, 2011
    122
    ontario Canada
    Is this something you access through the rear of tractor or from top, below the seat?
    Is it usually hydraulic or mechanical ?
    thanks Iron@Dirt
  6. Richardjw~
    Apr 14, 2007
    318
    South Devon, U.K.
    yes, on a snap-ring by the shaft. If the groove wears the shaft can just pop out
  7. Iron@Dirt
    Aug 27, 2010
    305
    south lou.
    Rarely you can shim the shaft to push a little farther back but is temporary. The pto will eventialy need a rebuild. The whole housing will need to be pulled, put on a table and dissected. Not real complicated but a little tedious. There are two pins that press into the shifting colar that wear and limit stroke of the shifting gears ( use to polish new pins a little to make driveing them esier into the tight spot you have to work in). You have to thread a metric bolt a little longer than standard to pull pins out, forgot what size. If you have acsess to a manual it is a great help with sequence of steps.
  8. wsw
    Jan 27, 2011
    122
    ontario Canada
    But I access this from the rear of the tractor? I will have no problem doing this I am just not familiar with this machine, I just finnished a complete transmission rebuild on a Cat 966G loader. I work mostly on heavy equipment and also on Cat diesels in trucks and yachts.
    Thanks for your time
  9. Richardjw~
    Apr 14, 2007
    318
    South Devon, U.K.
    yes, the entire rear housing comes off from the centre/diff housing, sling it from the top-pink lift point
    make sure you eliminate the hyd/elec circuits before ripping the back off 'er
  10. wsw
    Jan 27, 2011
    122
    ontario Canada
    Thanks alot for your help guys
    Take Care
  11. Iron@Dirt
    Aug 27, 2010
    305
    south lou.
    Thanks Richard for the pic. Do you have the internals showing the speed selection? wsw, if you pull it apart I forgot to tell you about how easy it is to nick the oring around the sliding tube.
  12. Richardjw~
    Apr 14, 2007
    318
    South Devon, U.K.
    there's this line-art from the S/M
    i'll have a look in the training notes, but the actual S/M has 70 pages on R & I of this operation
  13. Richardjw~
    Apr 14, 2007
    318
    South Devon, U.K.
  14. Iron@Dirt
    Aug 27, 2010
    305
    south lou.
    Thanks for the drawings. Left the dealership 17 years ago and havent done one since, even the ones I rebuilt Case was updating parts to make more reliable. Didnt remember spring and ball. Last drawing shows pins hooking into sliding tube. Good luck.
