Slim Tech
Case TR310
Believe it's a 2016 year
S/n; NGM415547
No throttle response, will only idle. No codes that I can find? Not 100% how to pull the codes on this screen.
All the fuses are good, no hot relays, swapped around relays just to be sure, nothing corroded in fuse/relay box.
Power going to the throttle control lever.
I believe there to be power going to the throttle motor, 10.86V, but it does not flunctuate with the throttle control so I may have not hooked up to the throttle motor, it was a 2 wire plug on top of the injection pump.
Any thoughts or ideas? I'm leaning towards faulty motor, but want to be sure.
Thank you
S/n; NGM415547
Thank you
