gggraham
Had a customer park his Case CX240 in an open field by some tall pine trees. Machine ran fine no problems machine had just over 4500 hrs. The next day he calls and says it won't start. Dash has no engine codes displayed but one code that meant "failure to communicate with ECU". Machine setup/language codes are fine but all machine history is gone. Machine hours are correct but no previous history. Hooked up laptop and cannot communicate with ECU. Checked all wiring had voltage in, no voltage coming out of ECU. Installed and programmed new ECU.....after that everything is fine starts and runs.
The next day we thought about it and the night before had been a violent thunder storm. There didn't appear to be any lightning strikes near machine but...kinda at a loss to explain the ECU failure. There doesn't seem to be any other explanation other than a voltage spike from lightning. Been around equipment a while and I think this is the first time I ever ran across something like this. I have never replaced an ECU on a Case Excavator and have never seen machine history totally erased from a machine yet the machine language settings are fine. Anyone ever run across something like this on any equipment? I have seen Gomaco DC units go down from the static spikes/ backfeed from grade and steer wands but thats it.
