Case 621C instrument cluster problem
Pat E
central queensland Australia
Hi Guys, My 621c instrument cluster (part no.278823A4) has gone blank also disabling trans and bucket controls. Engine starts and runs. Instrument cluster will light all readouts and warning lights when program switch is pushed, will also show correct readouts of oil press, temp, trans selection etc when program switch is held down but won't allow trans or bucket movement. Once program switch is released, screen goes blank. Buzzer sounds continious. Fuses, relays, earths all checked, cleaned and good. Power and earths to IC are good. Case tech manual resolution if power to pin 1 and 2 on IC is good (which it is) with blank screen and no trans/hyd controls is to replace IC which costs $5000. I have to order this from USA at my risk, if it doesnt fix it, tough luck. Has anyone seen this and does it sound right? Instrument cluster does contain computer that controls/overrides trans/hydraulics. Machine is very tidy and in excellent order with 5700 hours. Before this everything worked perfect.
If anyone can confirm this would be much appreciated
James Vaughan
Ireland
Hi Pat just came across your text , i have exactly the problems on a case 521d case loader and was wondering have you fixed it? , did u have to buy an Instrument cluster ? Thanks James
GaryHoff
Alberta, Canada
Heavey Equipment Mechanic
Likely he had to replace the cluster, as there was power at pins 1 and 2.
Grounds are pins 8, 37, 38, 39,
The C series and D series use the same clusters.
Corey Watkins
West Virginia, USA
I was wondering Pat did you have to buy a new cluster or not. I have a 721 D doing the same thing and I cant seem to fix it. I had my cluster sent to a company that fixes green boards and they said they fixed some stuff on it but when I got it back and put it on the machine. It did the same thing like they did nothing to it. I need help. Do just need to get a new one or a refurbished one or what. Thank you
Coy Lancaster
Arkansas
service tech
You’ll need to replace the cluster in your machine.
Nebraska USA
Did you find out what was wrong? What was it? Also where did you send your IC to get it fixed?
William
JOHN BAVARO
INDIANA
HEY GUYS , we have the same issues with a instrument cluster on a CASE 721 and we find this guys FROM Dashboard Instrument Cluster in Toronto Canada . They fix it for us . I understand they have a office in Miami USA too and i was told by our local Case dealership they are approved CASE refurbished / repair facility . i hope that will help
bigahmad09
Usa
Hi John I have a 2000 case 721c and my cluster went out abd cause the machine from moving and the hydraulic to move. I called that cluster repair company down in miami and sent them cluster to get it checked. They told me to repair my cluster they wanted 6000 dollars. I told him ur insane 6k just to fix a cluster. I told him no sorry I can't please send me back my cluster he said there is a $730 for check up fee. It jumped from $150 check up fee to $730 fee. I'm like I'm not gonna pay you 730 for u to just loom at it. So my cluster is still at his shop and I'm trying to find a used refurbished or new one but I haven't had any luck yet. I called lots of places non of them got it. I was hoping if anyone of you find out where I can buy it. I need on ASAP.
bigahmad09
Usa
Hi how much did you pay for the repairs?
