Case 621
Coy Lancaster
Arkansas
service tech
Hey Case guys I’m looking for some information on a transmission shifter for a Case 621 loader. I don’t have the specific serial number but it falls in the JAK0021701-JAK0027512. It has the ZF 4WG-150 transmission. The information I need is on the shifter, it’s the big one I think it was made by Bosch part number is A187760 subs to 75239663. What I’m looking for is the part numbers for the micro switch inside the shifter.
If anyone has a break down of the shifter that would be great or any other information on parts.
Thanks in advance for your help.
Vetech63
Oklahoma
Have you taken the shifter apart? Sometimes the switches will have the manufacturers name and part/model number on them.
Coy Lancaster
Arkansas
service tech
I have taken the cover off and tested the switches that's how I found out one is bad. I haven't taken the switches out of the housing yet the indicator ring at the bottom of the handle is being stubborn and not wanting to come off. I don't want to break it so I will work on that today.
old timer
manitoba canada
field mechanic
That is a Clark shifter, the early ones used it. The last one i rebuilt I went to a local electronics shop and picked them up.
Hope this helps
Bigbert
Germany
Consulting Engineer
Hi guys,
I must admit, never saw this shifter in ZF. Old timer is right, this is a Clark type.
I'm actually impressed how it works with EST17T or EST25.;)
Coy Lancaster
Arkansas
service tech
Hope this helps
Thanks Old Timer I appreciate your feed back. I couldn't remember if it was a clark or bosch shifter. Bad thing is there aren't any electronic stores around anymore. I'm sure I can find something on line.
Coy Lancaster
Arkansas
service tech
Hi guys,
Hey Big Bert; Case started with the clark tranny in the 621's but they wouldn't stay together.
Coy Lancaster
Arkansas
service tech
17F7B06A-74DB-41AC-83A0-B15BA1F895CA.jpeg BA8AA1CE-3B20-4917-A6E8-D21D20F9429D.jpeg 17F7B06A-74DB-41AC-83A0-B15BA1F895CA.jpeg Hey guys here’s an update on gear selector. Here are s the micro switch I need if anyone has any idea on where I can find one I’d appreciate it.
Sorry for double pic.
Coy Lancaster
Arkansas
service tech
Update on micro switch guy's I found one from a company in the UK. The original is obsolete but they had just one of an updated version. Thanks for all the input and help.
Coy Lancaster
Arkansas
service tech
Well here it is the last of Sept. and just found a micro switch from Case no less. I did another search earlier for the complete control lever and found the breakdown of lever with part numbers for switches ordered one through Case, quite pricey, but it worked. I also was in need of the connector for the control valve solenoid harness on main harness side. Found it through Case also. Had parts manager contact Case for the breakdown of harness and they came up with the mfg. part number. So now I will have to rewire and test each individual wire to get them in the right place. More to follow when I get connector in, hopefully will be good news.
