Midnightmoon
I have a large coffee can full of those switches in different flavors
Thanks Nige for the info, the one i needed didn't have the lever just a button. I'll keep this in mind though.A bit late in the day but I remember microswitches a lot like that one on the older non-electronic wheel loader transmission shifter controls for the backup alarm and the transmission neutralizer. The Cat Part Number is 9N-1750. 3 terminations, common, NO, & NC.
View attachment 245740View attachment 245741
The microswitch is the same I think. The lever is only held in place by a rivet and the operating button is right underneath it.Thanks Nige for the info, the one i needed didn't have the lever just a button. I'll keep this in mind though.
How did your rebuild go? I in the process of trying to find micro switches nowThanks Nige for the info, the one i needed didn't have the lever just a button. I'll keep this in mind though.
I actually found a break down of the shifter on AVS.com website. I'll try and find the photo and share it with you.How did your rebuild go? I in the process of trying to find micro switches now
Good luck I hope it works for you.I appreciate your fast reply. Hoping to make these micro switches work. I have to get the arm off and I think it might work.
Thanks! It actually worked perfectly. So glad I didn’t spend the 3500 on replacement. Cost me $30! Thanks againGood luck I hope it works for you.
Can you remember the part number on micro switch you ordered from UK ? need two switched in my wheel loader as well now, having hell finding em here around texasThank you but I have that number. The complete shift lever is over 3,000.00 "YIKES" but I did find a micro switch in the UK that I have on order.
if you dont mind, can you send me the part number or where you ordered it? thanks need the micro switches for my fiat loaderThanks! It actually worked perfectly. So glad I didn’t spend the 3500 on replacement. Cost me $30! Thanks again
