A bit of a delay as I had a lot of other things to do. I bought a couple of chain hoists, attached them to purlins in our garage, removed the inner circlips from the front pins of the lifting rams, tapped them through a bit, dropped the front bucket, supported the lifting rams by a rope across the bonnet, disconnected and blanked the other 4 hydraulic hoses, connected the hoists by ropes to the back end of the forks and took the weight of the forks. I then drifted out the lift ram pins. The big problem was getting the long rear pivot shaft out, it took ages. I then reversed the digger away from the forks, it was a very tight fit.
So now I am hoping for advice again. It looks like your suggestions about the digger having had a hard life are proven on inspection it seems that the principal support for that pivot plate was not the weld around its outer edge but halfway in where it had been welded in the factory to the tube which runs from side to side and which it now elliptical, it seems that that weld was broken years ago and the plate was welded back just around the edge, and those welds seem to have had very poor penetration. The original weld to the inner tube must have been done at the factory, there is no way of accessing that space now to re-weld it, there is no play available on the pivot shaft so an external plate cannot be added. It may be possible to weld a plate inside, narrow enough to get in the hole but even then you would not be able to connect it to the pivot plate, therefore my plan is to rely on having the pivot plate professionally welded around the outside edge with correct penetration.
Once welded I have big concerns about getting the forks back on. As I said the forks were on very tight, driving forward I am concerned about the forks slipping and smashing the lower windows, after that I am concerned about how to get the long pivot shaft back again, I can't see much chance of getting the fork bearing in line and sliding in from one side, even though there is a dimple in the end of the shaft, lining it up that way looks like a nightmare, is it possible to install it before driving the digger forward and then fit one side at a time? The bearings are quite long and I don't know if they could cope with the degree of twist necessary.
Thanks,
Michael
