Jeff Munafo
I have a case 580c. When I go to start the unit, it draws down on a freshly charged battery to 10 amps or slightly less. It's my understanding that this unit needs 12 amps to properly turn over. A few days ago I was using it and installed as I was going to pick something up with it. I restarted it and it seemed fine for a while. Then later on that day it did the same thing installed when I went to pick something up with it. Again I started it and it seemed to be fine. The machine had been blowing black smoke for a few months which I now believe might be from over pressurizing of the fuel injection pump??? So yesterday the machine stalled, I went to restart it and it struggled turning over as if something was seizing and fighting the motor from turning over. After several attempts I got it started but I had to keep my foot on the gas all the way as it was struggling to stay running. Then it's slowly began the best I can explain seize up and stop. Eventually after numerous times of trying to start it, it sounded like it wanted to start but it just wouldn't. So today is when I put the booster pack on and when I got home I got it to start with the gas pedal all the way down and then it started to fight and slowly started to die within 30 seconds or less. I definitely have fuel at the injector pump. My question, is it possible that the fuel injector pump is seizing up and fighting the motor from turning over? I did break the the glass on the check valve just in case and to ensure it was not an issue with a blockage. At one point the engine just plain stopped as if it had seized and I would gather there is definitely something causing a seizure or slowing of the cranking process. But typically when an engine seizes it doesn't start turning over again, and certainly it doesn't start and run again in most cases with a mechanical failure. I mean I've seen it all and yes it's possible I suppose but my guess is it might be the pump for the fuel injector?? Any thoughts suggestions ideas as to my assessment, right wrong or indifferent??
