g ryan
case 580b shuttle pump
Ron,read U'r posts w/ Phil's..Big Help. This is what I'm playing with: Loss of power like Ur's but my dash gauge is in the Green and still minimum power in
foward and rev. I tested the pressure @ the shuttle valve cover (removed the small pipe plug and installed a gauge) and measured 25 psi.. Was that
correct place to test ??? but my ??? is How can it be in the green on the dash gauge and measure 25psi at the spool ?? any help.. G ryan
By the way, I'm dying to know what the pressures are at the valve body, the pump pressure, and torque charge pressure so I know what does work on this particular unit and now I can check them if a problem exists. Manuals are god but I find that actual pressure reading when working well is valuable info in my field of practice. I will post them here. Ron.
