HI All, I am having some trouble with the shuttle on my backhoe. when I first start it up it moves ok. then after a while forward does not work and reverse slips and engages and slips. then if I shut it off for just a few seconds it will start to move again but any pushing into anything will cause it to go out. Today I drained the fluid twice from the pan but did not drop the pan yet. it is a 4x4 and it seems I would need to remove the drive shaft and the protective steel housing running along under the shaft and pan. Can anyone offer any advice on where to start troubleshooting this? I guess my next step will be to drop the driveshaft and pan and check the screen? then what??
Thanks
Thanks
