JedCase580SE
I got a Case 580SE Backhoe a few months ago. It had almost no forward drive but reverse seemed fine. I did the pressure gauge checks in the manual and found the forward clutch pressure to be lower then reverse and figured that the forward clutch discs were probably shot. (Bad choice)
I removed the shuttle, disassembled it and found the discs did not look very bad but since I had bought the full rebuilt kit I redid everything. I was hoping the discs were bad enough that they were the problem.
Now I have it all back together and running and still no forward.
I am going to put the gauge back on it and see if the results are any different. What else should I do?? I have already decided I am probably going to have to pull the shuttle again and see if there is something that I missed. I hate doing this again but I think it has to be something in the shuttle.
Also, there are no wires on the solenoid cutout so I figured it’s not the problem.
Any ideas will be great.
Thanks
Thanks
