Yes, once the starter is spinning fast, it's not going to engage the ring gear teeth if it hasn't already. That's why the back of the teeth are ground at a bevel, so that the teeth will move slightly to engage as the solenoid moves the starter gear out, and HOPEFULLY before it starts spinning. 0.060" to a carpenter is 1/16" which is half of 1/8" and it looks to me like you have 1/8" wiped off of those ring gear teeth already, plus they're smeared a little round, and a little of a burr on the edge. That combined with what DMiller said, makes it understandable that the starter won't engage, BUT you say it will engage for a second, and the engine turns a bit? before it kicks out, I don't get that. And I've never seen such uniformly ground teeth on a ring gear, so I'm suspicious that there's something serious and unexpected wrong going on here.
