Case 570lxt cranks but no start
Mark Piascik
lake elsinore
Help please. Parked my 570 last night. It ran fine. Tried to start it this morning. It fired off like normal for 2 seconds then quit like someone turned off the key. Filled the tank with fuel. changed the fuel filter. checked the fuel flow to the injector pump. plenty of volume Checked the fuel shut off solenoid. Its getting 12 volts with the key on and it clicks when plugged in. I loosened the small line on top of the pump and operated the fuel pump lever until fuel came out and retightened it. I loosened the lines to the injectors and cranked the motor and I'm not getting any fuel out of the injector pump. Is there something i should check before i replace the pump. I'd hate to spend all that money on a new pump if its something simple. Thanks
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Mark, welcome to the site..
Can us nap a pick of the inj. pump n post it.??
If not click on my screen name n it will give u my contact info..& send a pick there..
There’s probably no need to buy a new pump..
jimg984
ronda north carolina
check for fuel return from pump to tank,, check return line and banjo fitting on pump where the return connects, if not a fuel return no run GL thepumpguysc is the best
