Motor is out and have taken a look.In pic 1 you can see how the bearing spacer is wearing unevenly,it is getting cocked to one side under load I presume.In pic 2 you can see where the shaft is wearing the top of the gasket causing the gusher of oil into the chain drive resevoir.
Is this the spacer you spoke of Goose?
I presume this spacer preloads the tapered bearings,if so I can deal with this.Maybe a little tungsten tig rod after a preheat and a grind job after I have determined the thickness.
The clip is no problem we have a tool,the bearings look great as do the chains and sprockets!!!!!!
The wasted gasket,this will be found,if I can't I will turn out some of the land and make it nominal ,not special metric crap?
Over all this motor is still ****!A total pain in the ass to get out!!As I see it,the spacer is letting the shaft deflect enough to take the seal out.Not really to much to these things as I see it,I could never justify throwing it out for these fixable issues.
OH,almost forgot,the seal journal looks great as does the I.D. of the pump housing.All have been measured and are within .005.
I'll take some pics of the fix if anyone gives a $hit.
