thepumpguysc
- Joined
- Mar 18, 2010
- Messages
- 7,535
- Location
- Sunny South Carolina
- Occupation
- Master Inj.Pump rebuilder
If using loc-tite, BOTH surfaces need to be de-greased.. use brake cleaner or starting fluid & blow dry.
Dont know the valve lash. I cleaned both surfaces with brake cleaner and applied some blue loc tite going to let it cure for a day. See how this thing runs in a day. Thanks for all the helpThat is a first. I never seen a set up like that. Degrease the surfaces and use blue loctite. If you know your valve lash. Then put each cylinder at tdc and adjust accordingly.
Well I didn’t start it yet. I cant seem to find anything online (manual). No tags on the valve coverYou should set your valve lash to its proper settings. To loose and you will get a dead cylinder and broken or bent push rods. To tight and you could lose compression or cause the cam lobe to wear faster. There may be a tag on the valve cover that will tell you the valve lash.
So if i put cyl 3 at tdc then i adjust number 1? Its very hard to see the crank pulley on this machine the cab doesn’t tilt or anything. If both valves are closed on 3 i should adjust number 1?These specs are for the gasoline version of your engine. So use it as a basis.
Intake is .014"
Exhaust .018"
Put one of the other cylinders at tdc and check the clearance of valves and see how close it is to these specs. Or at least adjust number 1 the same.
And if a particular cylinder is at TDC and both the valves are open then turn the engine one complete revolution in the direction of rotation and you'll be in the correct spot.Each cylinder has its own tdc. If the cylinder is is all the way up and both valves are closed. Then that cylinder is at tdc and that is the one you want to adjust.
I don't know what the specs are for your engine. I am just don't know enough about your engine to say with confidence that is it. If it were me I would check the other cylinders and run number 1 the same. As far as I know those aren't giving you any problems, so go with what is working.
No. That is the specified/desired clearance between the stem of the valve and the bore of the valve guide in the cylinder head, not the clearance between the top of the valve stem and the rocker arm.View attachment 264207
Would it be desired clearance ?
Thanks loc-tite temporally orderd new rocker. Thanks for the help everyoneThat type of set up has an interference thread they are meant to be quite firm to turn when adjusting.
The Case 188 & 207 engines are similar.
I wouldn't trust the loctite to hold it long term.
Another vote for replacing the rocker arm.
The tappet settings are .012" & .018"
I have a 1830 its a deal to work on. Mine is gas and i hear parts are hard to find . Its been a great machine but i fear the day i have a big problem.Yes they are all a little out of adjustment. Adjustment would deff help. Waiting for new rocker arm and bolt then will do them all. Machine really sucks to work on cab doesn’t tilt
