Hello, I'm looking to buy a old Carco model F winch for My cat D6c, i have no experiance of winches. Does anywone have used that kind of winch and is it a good model?? Where can i get a hold of specs or pictures off the winch inside?
The powershift version has an internal hydraulic operated clutch in order to disconnect the constant running pto shaft so that it can be shifted. Don't even think about running a direct drive winch on a powershift unit by stop/starting the engine to shift. That is a death wish in the making.
Yes, it can be done, but you need to be very smart and alert. It can be bloody dangerous. I know I have a sliding gear winch on my powershift HD6. I just put the powershift lever into gear to stall the converter and output shaft. Engage winch, release brake and take tractor out of gear. winch will wind in or out. Problem is; if you have any load on the winch whatsoever when you want to stop winching, it won,t come out of gear. this is where people get into trouble. You can,t go logging, its ok for abit of salvage work where your only using it very occasionally.
OM was very right in his warning about not using it. Have now got a powershift winch for that crawler and I intend to change it when time permits.
