Can I pull a RD7 to see if the big motor is stuck
My RD7 has a stuck pony motor, which I will remove and repair, can I pull it or how else can I see if the big motor turns it has a front mount hyd pump
Dave Neubert
If you got something that will pull it you can put the transmission in a high gear and release the clutch then engage the clutch once rolling
How do I get the 2 bolts out that hold the pony motor clutch housing to the diesel block when I don't have a top cover on the clutch housing and I can't get a socket in past the starting motor clutch ?
Old Magnet
That's strange, the early clutch housings had the three top bolts exposed, the later ones had two bolts accessible by removing the cover, third bolt is exposed.
ok mine has 3 exposed I have removed 13 from the pony to the block and 2 on the drive housing end and it still doesn't want to come off I haven't pried very hard for fear of hurting something maybe I need to get a little rougher
