Cabs and Seats - We need your help!
BRO1234
USA
We need your help. I am a member of an Innovation Team for a company that designs and manufactures components for heavy equipment cabs. Our team has been tasked with coming up with new product ideas and improvements that will make machine operators safer, more comfortable and more productive. We would like any and all feedback we can get on cabs, controls, seats, seat suspensions and restraint systems (seat belts). No holds barred - tell us what you think. Feel free to tell us what you don't like.
Greg
Wi
Excavating Contractor
Keep it simple and rugged. Make it easy to adjust. About the only thing I want is to be able to set the angle on the back to suit me. Make the cushions easy to replace. They will wear out. Make the cushions easy to keep clean. So many things today have become over designed with lots of features that never get used. So once again, keep it simple
wornout wrench
canada
Think about the poor mechanic that will need to get in there to repair something when it breaks!
AND IT WILL BREAK!!!
It all breaks
Try to have the wiring in the cab protected so when the operator throws all his supplies behind the seat it doesn't cause problems.
Same with the HVAC, get it off the floor so it doesn't plug up with dirt and junk. I have lost track of all the times I have had to take a HVAC unit apart and clean out the cores so that the air will flow.
Go away from hardened glass. One tiny little flying object and the glass is gone, usually all through the cab. What was wrong with good old laminated glass, or lexan on the side windows?
Just my $0.02 from a worn out mechanic:D
kshansen
Central New York, USA
It all breaks
Also don't cheap out on materials, some cab are made with flimsy plastic that cracks way too easy. Not against plastic just when it is to flimsy.
Also think about fasteners, don't try to be too fancy or hide them. Just because it's simple to snap things together on the assembly line. Someone will need to remove panels to do repairs and those fancy clips and fasteners waste time and end up breaking.
I for one do not like all the fancy curved glass that is so popular these days. I know you make money selling that stuff but flat laminated glass is easy for a local glass shop to cut and install in less time than it takes to locate one of those curved windows, and heaven forbid that it gets broke in shipment! You can be the one to tell the boss that his 1/4 million dollar new machine is red tagged for safety because of a broken window that came in broke!
Make wear items like sliders and latches easy to buy and replace. Don't tell me I need to replace the door assembly because some little plastic guide wore out and now the window keeps falling out. Remember you are making cabs for machines that bounce around and get dirty, both cause wear so design for these conditions.
Make controls and switches easy to see and operated. Don't have a dozen identical rocker switches that one has to look directly at to see which one does what. Also remember many of the people running this equipment may be wearing gloves, heavy clothes in bad weather and hard hats due to safety regulations and heavy boots. What may seem simple while sitting at a computer drawing up a design in CAD can become a major safety problem while bouncing along an unimproved road in a construction site.
If you feel the need to use little pictographs/symbols to label controls so operators who, say might not speak English as their main language can run the machine put a decal somewhere easy to view that explains what that little picture with the waves in it and little thermometer is all about.
And yes to all the previous suggestions!
PS. Might be good to stop by a few construction sites and quarry operations and get a look at the operators you are designing these cabs for. Not sure about other places but around this area most are not exactly skinny little people. So seats need to be strong enough and access ways need to be wide enough for fast and safe access. It's easy to slide a seat ahead for the small guy but not always easy for Big Ed! Try to fit a 275++lb. line backer into some skid-steers!
Great comments!
I'll add a few. First and foremost (which as already been stated) remove the A/C unit from under the damn seat! It plugs with dirt no matter how clean you try to be and is a PITA to get to. These machine work in dusty, muddy, dirty environments and it's just a matter of time before you have to become a contortionist to break the cab down and clean or repair the unit.
Never, ever put another seat in a piece of equipment that has the manual crank to adjust the height of the seat - the one with the green and red crank dial that tells you how high or low the seat is. They all suck, replace that with an air adjusted seat.
Use a more robust HVAC louvers on the vents, some are cheap and flimsy, which break over time.
Use real bolts to put the cab internals together not those funky screws that require some sort of star bit that you never seem to have the correct size in your toolbox.
Better routing of electrical wires and harnesses in the cab, don't let them just lay behind the seat or dangle on the door -Bobcat skid steers for instance.
ttazzman
missouri
a washable floor that drains good...soundproofing..... hard washable surfaces....ceiling heat and air positive air pressure....the last cat seat i took out was ridiculous musta weighted 80pds uncomfortable was heck damn near impossible to recover suspension was another 50pounds and didnt work right....flat glass that is replaceable without having to break rubber gasket seals...put in nice cup holders etc....extra 12v power taps for phones and laptops..bluetooth etc...
Jim D
California
equipment operator
as others have said; air suspension for the seat, air adjust lumbar support, arm rests that don't fall off, wrist rests that adjust.
Seat parts that can be replaced. Use large steel screws and steel captive nuts for fastening, not plastic fasteners.
for seats in equipment that travel and backup, mock-up and demo and test how an operator will look behind when backing; hand holds and grips that help the operator twist his or her upper body to look backwards are a big thing that reduces fatigue.
Jim D
California
equipment operator
PS
if switch gear is part of your design scope, don't make all of the switches the same and don't put them all in one cluster. Distribute the switches and make them distinctive to the touch. Operators should be able to reach for a switch, knowing where it is without looking, and know it is the right switch when they touch it.
Deere has a very stupid switch pad where almost all of the switches are stuck in a small checkerboard. Want to flash the lights at someone? It's the third from the right and the second form the bottom square. (something like that... front lights or back lights...) A blob of mud lands on the windshield? Stop. Put on your bifocals to see the switch pad. Two wiper switches, one is the back and one is the front, but the symbols are exactly the same. Learn which is which. Press the front wiper switch. The front wiper is in intermediate mode. Press the switch again, the wiper is in slow speed. Press the switch again, the wiper is in fast speed. Press the switch again and the wiper stops. Stupid! That could have only have been designed by computer game kids. Anyone who is used to knowing to reach up on the right to the middle switch for the wipers, or down and behind for a twist knob for the lights, will see that the small square switch pad, that you need to look at, off to the side, is dangerous.
edit: sorry, I just saw that I duplicated kshansen's switch complaint. He is right!
Plant Fitter
Most things have been covered, but I will add:
Accomodate operators of all sizes.
Tall people often suffer in cabs. I'm 6'3"
I've been in cabins where I can't see the horizon without hunching down because the windscreen doesn't go high enough.
I've been in cabins where I can't wear a hat because there is no headroom.
I've sat in seats where the headrest is pushing on my shoulders.
I've sat in seats where the lumbar support was about 4 inches too low to give lumbar support.
I've sat in seats where the arm rests are too low to rest your arms on.
BRO1234
USA
Once again, this is all very good input. And again, please feel free to add more material as you think of it. This not falling on deaf ears. A lot of the comments we are seeing we have heard before - this all just underscores it!
kshansen
And I can understand some of the problems you run into from your end of the story. Too often those who make a decision on how something is made are too interested in how "pretty" it will look in the full color advertisement in the trade magazine, or how they can lower the cost by five dollars to meet some pencil pusher's idea of how much something should cost.
If you want to do some research into the problems this can cause look into the problems General Motors had with the Corvair back in the 1960's. Most of the handling problems that Ralph Nader made his name pointing out would have been avoided by the addition of a sway bar that was something like a $15.00 option. But the inclusion of that part would have pushed the selling price just over the projected market price.
And no telling how many millions GM is having to pay to replace faulty ignition switches and pay for deaths of those who had them fail at just the wrong time. I can bet there is somewhere a designer who tried to convince someone to make some improvement but was told "No, that's too much money"
kshansen
While I'm up on my soap box, How much would anyone be willing to add to the price of say a new D6 Dozer to have all hardware or even just the belly pan and under carriage bolts dipped in anti-seize at the factory?
I've had things as simple as a 12 mm bolt holding a hood on a machine that was only 2 years old that had rusted so tight that the weld-on nuts would break loose. Glad Norm was a skinny kid back then and could slide up under that hood to hold the nuts with a wrench! Welded nuts back on and now after putting anti-seize on them back in 1998, 16 years later I know they will turn out with my fingers after a good tug to break them loose.
Mike L
Maine
Self employed field mechanic
how about shaving some weight off of those seats. every time I have to pull out a seat, I have to get a tune-up at the chiropractors. they're heavy, awkward, and a pita to get outside of the cab. also, why do they have to cost so much? its a freakin' seat! I don't understand why I can buy the nicest leather air operated truck seat for $1000 but a standard cloth equipment seat is $3000-4000.
BRO1234
USA
Thanks again everyone for the great feedback - just what we were looking for. We'd like to pose a question - mainly for operators - is there anything specific (besides what has already been mentioned) about the cab or the seat that 'takes away' from your comfort, safety and efficiency. In addition to making our product better at a fundamental level (more durable and reliable, easier to fix, clean and replace), we are looking for ideas that would lead to better features and enhancements. Like before, anything goes. We want the whole cab/seat package to better work with the operator. We would also like to know what machines you operate to further helps us. Thanks.
stondad
Queensland Australia
Truck Driver
I can't think of anything to add to the replies before your #16, that answer your questions any better than others already have, so maybe I can throw something in that will get some comment.
I am a tip-truck owner and most of the time use the machine at wherever I load to load myself.
Therefore I have experienced a wide range and age of different brand and age of loaders and excavators, but probably never spent more than 1000hrs in any one machine.
I don't advocate that you "copy" anyone, but let's see what everyone thinks about what I remember as "standout" features of the Volvo loader cab.
*Big wide gnarly steps and plenty of grab handles in just the right places.
*Big wide door that is easy to open without having to lean back or go down a step to let it open.
*Nice big area at the top of the steps and level with the cab floor, so there is room for your feet to easily turn to go down the steps, or turn before sitting down.
*The seat is mounted on a plate that comes off the back wall of the cab about 4 or 6 inches above the floor so there is no seat mounts or brackets to clutter the floor and tangle up stuff that you shouldn't have in the cab with you. The first time you see that plate coming off the back of the cab, you think it is a weak point, but I have never seen one broken.
*Big, single piece, flat back window. Exhaust stack in the middle so it hardly ever restricts vision.
*No door on the right hand side but a big swing open window that is big enough to get out if you park the machine on it's left side !
*Big slide up and down window in the door so that if the aircon is u/s, with the two windows open, it's not too bad.
*Excellent vision all round.
*Quiet.
*Beautiful pilot operated hydraulic control levers with an adjustable wrist pad. (Gotta say that Case may be even better !)
Some points already made that they suffer from.
*"International" symbols on switches that are even more difficult when the picture wears off. (I got in a really new one recently, and had to be shown where to even put the ignition key!)
*Curved front windscreen that I would hate to have to pay for.
Hope this helps.
FarmWrench
Chaffee NY
Table Potato farmer
If I had a dime for every mouse nest. My case 2388 combine has so far proven mouse free.
I hate:
"Nader pegs" for the door that catch pockets and hammer loops. Seat belts that you can't unhook with gloves. Floor mats that you can't clean, won't the manualp dirt off the steel underneath and chemically break down from grease and oil. No place to keep the manual.
I'll repeat the switch gripe. Glass and seat comments.
lantraxco
Elsewhen
Whenever possible the key switch should be mounted on a flat or near flat surface with two or three inches of clear space all around. Many operators have key rings with lots of keys on them, you don't want all that weight hanging on the key switch, and on the flat you don't want anything for all those keys to hang up on and maybe jam the the switch in the start position. Seen it happen, starter, cables, and flywheel ring gear later..... "I didn't hear anything!"
clintm
charlotte nc
The only trouble with the key switch being mounted on a flat surface is it collects dirt in it and jams up and it's hard to clean out with air or wd-40 but had a volvo l120c about 1,000 hrs that the switch was mounted on a vertical surface beside the steering column it shut down when you would hit a good bump or shake the cab it took us a while to figure out what was causing the shut down because it would not turn the switch off just enough to kill the engine also used that big square volvo key cut the rubber off the key and drilled a hole in the center of the key for ring problem solved I'am thinking thats the problem with the chevy's ever seen a women's chain of keys,customer cards,pictures and any thing else that can be on a ring. An engineer told me once that the reason the seat mounts on volvo loaders are angled down in the front is because it is easier to slide the forward because its down hill makes sense ever tried to slide an older seat forward have to get up turn around and pull on back of seat while moving lever with other hand or knee. have a 972k that the cab sucks cannot see out the back hard to turn around hood in the way, back window to low ,small sliding window on right side thats hard to slide ever tried to talk to a half deaf truck driver through a 6" wide window, the round window that come from the factory with a wave in it that was at about 2:00 it was like looking through funny glass at the fair try loading the bucket out of the stockpile thats over 15-30' tall and looking up thinking that it's caving off on you
