BS3F Mitsubishi track loader starter part number
Chris crouch
Winnie tx
I am looking for a starter for a BS3F Mitsubishi track loader. I purchased this from an older gentleman about two months ago out of South East Texas. The starter was not with the machine. No problem I thought... I’m on my 4th starter and no luck. If someone has a pn or can help I’d appreciate it
lantraxco
Elsewhen
I doubt you'll find any information on that this side of Japan, but I may have a friend... got a serial number? And/or engine model and serial number? and is it 12 volt?
Chris crouch
Winnie tx
I found the data plate and discovered a number BS3D. I assumed it was a bs3f because of the decals.
the other numbers on the plate are
14593
100192
they both are in japanese so i do not know whuch is the SN
JimInOz
Victoria, Australia
BS3D might have a 4DQ-50 engine.
4DQ starters : 12 Volt starters...30666-23108 or 30666-25100
: 24 V starter... 30666-23301.
Chris crouch
Winnie tx
I was wrong once again. the starter seemed to be right but was clocked wrong.
I tried to look those pn up and their seem to be alot of variations also. is there a specific place you would order from?
JimInOz
Victoria, Australia
There seems to be a lot of Mitsubishi starters & numbers,just to make life confusing.There were also many 4 cylinder engines made.
You need to identify the engine model.Should be a plate on the engine,or embossed numbers & letters.
Usually,the BD2/BS3 crawlers are 24Volt. Excavators too.The Forklifts were probably 12Volt. There might have been Marine versions of the Mitsubishi engines also.
Maybe try and find another D model owner & see if they can quote starter details.
Mitsubishi forklift agents might be of help too,as can diesel engine parts suppliers.
Chris crouch
Winnie tx
So I managed to find a number in the engine. It’s a 4dq50
I then found a parts book for that engine and it looks like I’m needing a M002T54172. I have a guy here locally that thinks he has got before I order from overseas and pay an arm and a leg. Crossing my fingers and saying my prayers! I’ve only got the wrong starter 7 times
