Bore welding help
Discussion in 'Shop Talk' started by Volvomad, Mar 2, 2020.
  1. Theweldor
    Theweldor Senior Member
    Feb 17, 2018
    518
    Western, NY
    As Nige said there is no setup to run the bore welder. Just slide the bar out and slide the bore welder in. Only takes 5 minutes.
  2. Tugger2
    Tugger2 Senior Member
    Mar 22, 2018
    623
    British Columbia
    Much easier to take a quick cut than wear away at it with the die grinder
    Labparamour likes this.
  3. Theweldor
    Feb 17, 2018
    518
    Western, NY
    Here's one for ya This was done horizontal. There is a bit of a learning curve. KIMG0100.jpg
  4. RayF
    RayF Senior Member
    Jul 9, 2011
    635
    lineborer/welder
    Perth Western australia
    I don't drop in as much as I used to. I run a Line Boring group on FB which is more focused than what you can do here. If anyone is interested I can reply to a PM.
    Answering the topic,its a big risk welding bores before a prep cut and I can't think of a reason not to. As far as penetration and laminations go its not an issue if you have the welder set right and are using the correct gas. You can get a perfect weld. DSC04603.JPG
    DB2, Ronsii, Nige and 4 others like this.
  5. Nige
    Nige Senior Member
    15,555
    Right there is that fine screw thread appearance I was talking about previously.
    I’ll admit straight up that I’m not a welding expert but I do know what a good bore weld is supposed to look like..... :cool:
  6. Theweldor
    Feb 17, 2018
    518
    Western, NY
    So do I, but it can be an episode sometimes to achieve it.
  7. Welder Dave
    Welder Dave Senior Member
    Oct 12, 2014
    4,516
    Almost like a phonograph finish when machining. Pretty fast travel speed to get the narrow bead. First pass would be the trickiest.
  8. Nige
    Nige Senior Member
    15,555
    As my old grandad always used to say - "99% preparation, 1% perspiration."
    TNB and Ronsii like this.
  9. RayF
    RayF Senior Member
    Jul 9, 2011
    635
    lineborer/welder
    Prior preparation prevents pi55 poor perfomance
  10. Welder Dave
    Oct 12, 2014
    4,516
    Curious if when doing a horizontal weld, a back up strip is tacked/clamped in place to be able to weld right to the bottom edge of the bore?
  11. Theweldor
    Feb 17, 2018
    518
    Western, NY
    I have never used any type of backup ring. You can get the full width of the boss and even gain a little bit of width.
  12. Nige
    Nige Senior Member
    15,555
    Is one reason behind that because each ring of weld is depositing such a small quantity of metal per rotation.?
  13. Welder Dave
    Oct 12, 2014
    4,516
    Do you have to change the angle of the nozzle for the first pass or if it droops doesn't really matter?
  14. Theweldor
    Feb 17, 2018
    518
    Western, NY
    If you look at the bore that RayF posted a picture of you can see where the weld is just a bit above the face. If you start with the tip of the wire right on the bottom edge of the bore it will droop about the same. Nige is correct in that it is such a small deposit of metal and also the automation from the bore welder is so steady that it helps also.
    Once you set things up and turn everything on you are pretty much committed to were the nozzle is set. Because you tighten every thing in place. You can tamper with voltage,wire feed speed and travel speed but that is about it.
  15. RayF
    RayF Senior Member
    Jul 9, 2011
    635
    lineborer/welder
    I usually do a turn at the bottom with the wire turned down and let the bead bleed down a bit.Then another with the wire up a bit and then engage the feed.
    dirty4fun, Nige and Theweldor like this.
  16. Volvomad
    Volvomad Senior Member
    Jul 14, 2011
    300
    Ireland
    Fabricobble or codswallop. Ye decide 20200307_143519.jpg 20200229_171454.jpg 20200307_143519.jpg 20200229_171454.jpg 20200307_085920.jpg
    Jonas302 and Tugger2 like this.
  17. Theweldor
    Feb 17, 2018
    518
    Western, NY
    It appears as though you are gaining on the bore welding. There is a learning curve so don't give up.
    Not sure if that is your bore welder or the line bore. Does look a bit fabricobbled what ever it is. But refinements will come with time as you will want to make the operation more efficient. At any rate it does the job and that is what matters.
  18. Welder Dave
    Oct 12, 2014
    4,516
    That makes sense. Once you have a "shelf" you can turn your heat up a bit.
  19. Volvomad
    Jul 14, 2011
    300
    Ireland
    The photos arent great . That is in boring mode . A bidirectional vari speed motor driving the lead screw and a fixed 65 rpm driving the bar . It is only for in house use on 60 to 100mm bores.
  20. Volvomad
    Jul 14, 2011
    300
    Ireland
    A few more pics
