joelx777
This is the engine speed sensor. The controllers use it to set idle, low, economy, and max power settings as well as to handle the auto idle circuit (when no functions are in use it returns the engine from the current settings to idle and waits for operator input to rev up again). I tested the engine speed sensor and it works great, I had a previous post on it. Now my problem is where these wires go and why I have what appears to be a short circuit between the two, maybe at the connector as you previously mentioned. I actually made several posts above, did you see them?I am shooting in the dark here but appears you are talking about the "pump speed sensor" Maybe that is all the same? Certainly not on my CAT, but.....
Anyway, that diagram SUCKS! Hard to look at but appears that sensor is discrete (wires connect to nothing else), and only has 2 wires? If that is correct, that is likely an inductive pickup coil, in which it returns small voltage sine pulses back. Can confirm if there is a resistance spec for that sensor. If that is the case, you can easily just pull that plug from the ECM, put meter on it, and crank, ,and will be looking for AC BUT you have to be really careful as some RMS meters want to ignore anything outside of 60hz and this will be. A scope is your friend here!
If there is no AC wave form, go right back to the sensor. If you find it there, you have a culprit.
The AC amount is not that important. ECM will probably recognize anything over 5-10VAC, and will be looking for a sine wave so will have a trigger set in the programming. If it never hits that voltage, it is ignored.
Your idea of pulling the connector from the engine controller is interesting... The manual says in a few dozen places not to try to run the machine though without it as it could cause permanent damage? This is one of the first machines they used a computer controller like this... It's a 1996 model year. The engine speed sensor does have just two wires and does have a resistance spec. Right now I just have a multimeter and toner / probe, sounds like I might need a different tool to check? As I mentioned before, the sensor tests out and works.
I cut the two prong connector off the engine sensor side so I could test the wires better. I have to fix that. I think there is a short circuit maybe in the controller side connector or maybe in the wiring. Not really sure where to go on it... The new wiring schematic I posted for the engine controller connector that says the two wires outlet on pins 4 and 11 does not match my actual testing of the connector.
