hardscapes89
Hi, I am having some start up issues with my 07’ T320. After 4 days of not running the machine due to inclement weather I attempted to start up the machine and when the motor turned over and fired it only starts up for a couple seconds then shuts down with no codes flashing. No sputter or signs of lack of fuel flow, fuel primer pump doesn’t look constricted, changed fuel filter and checked fuel flow fuse/relay and even charged the battery. Unfortunately these attempts never solved the issue, it like something is shutting off fuel directly to the motor. Since the machine is not flashing codes its difficult to determine the cause of the immediate shutdown. Please keep in mind we have had 32 and below tempts for the past week. I called bobcat and they said just bring it in…Naturally. I have a shop where we service our equipment so the ability to work on the machine is no stranger to me.. If anyone has suggestions or possible leads to a solution it would be greatly appreciated. Thanks for your time.
