NCPIPELINE
Occasionally Bobcat does not raise and lower arms. Everything else works just fine. On board diagnosis says "Tilt actuator not in neutral" Help?!
you either have a sticking tilt spool, (aluminum rear bonnet may be loose), or you have a tilt actuator going bad
:drinkup
x2. I'd bet my money on the actuator. Either way it's going to be a PITA unless you are a contortionist.
hope your 2nd mechanic ran an actuator calibration.... uncalibrated actuators usally have a short life.
:drinkup
i guess its trial n error then.
On board diagnostics says "tilt actuator not in neutral" I believe it said code DP-2 is this correct?............
On board diagnostics says "tilt actuator not in neutral" I believe it said code DP-2 is this correct? Got it from guy on site via radio. Machine is running fine at this moment haven't done anything with it yet. Like I said it does it sporadically.
im sorry for jumping on someone elses thread. it will not let me post a new one for some reason. i am really going crazy with this machine. i have a bobcat 730. it was givin to me. i have got it running and moving forward and backwards. IT WILL NOT TURN... i dont have any idea what it could be.
the code you are seeing in the display isnt DP-2 it's DR-2. thats the default drive setting.
:drinkup
My A300 always displays the DR-2 also. I believe that it's the label for the Bobcat software that is installed on the machine. I don't know if it can be reprogramed.
