ejb17
I am looking at a Bobcat SB200 X 72 blower that looks real nice with little use. It was originally purchased in 7/04 and apparantly did not get used much. The current owner bought it in a package deal with a S175 that is also a 2004. The S175 has high flow(26 gpm) and my machine, a Komatsu SK820-5N, also has high flow at 26 gpm/ 3050 psi. I have to get the numbers off the fan motor to check displacement as Bobcat could not tell me how it was built even though I had the serial number. The current owner does not have the books so I can match up the hydraulic motor number to what the Bobcat manual says so can anyone here help me out when I get those numbers?
Any experiance you have with this blower is welcome also.
I do know I have to change the seven pin to 8 pin to match my machine but that should just be a plug change and checking the coil packs for opertion.
