Bobcat S70 seat bar sensor
Fullerton, California
Is there any way to bypass the seat bar sensor? I have replaced it with a new one but still having issues with it. Light will not go out.
I have 8 volts on the supply wire to sensor and, 5 volts on the signal wire to sensor.
crewchief888
NWI
most times i see the steel key bushing is not in the correctly aligned. ie: the slot in the cab is worn out or incorrect assembly.
the seat var sensor is a gall effect type switch, really now way to safely bypass it
