willie59
The only way to know for certain is to pluck the pick up tube out of the tank. I wouldn't go there unless troubleshooting points me that way.
I have a similar problem 2006 s 175 bobcat. I put a rebuilt motor in it and when i drive at full throttle no problem.If I try to dig into a pile of dirt it starts to stall out as soon as i feel put a load on motor.You need to clarify "bog down". Does that mean the engine loses RPM, or does that mean the engine holds its RPM but machine functions slow down? I ask this because you mention that under hard load you can hear "the belt slip and squeak". I assume you mean the drive belt. One thing for certain on a Bobcat, if things are proper, no matter what the load is you should never hear the drive belt squeak. If you do, that's a problem.
