pjcat
I recently purchased an older 753 serial# 508615824 The engine has only 1080h on it, but the machine was sitting for quiet a while. So I serviced everything, replaced hoses, the whole tlc. After all I tested the machine and it worked great, had to adjust the neutral a little and everything was fine.
Then on one of the drive motors oil started to leak; I found on one of the hoses the o-ring went bad. So I replaced it and the leak stopped. But now that motor is jerking in forward; I have to push the steering lever hard forward and back to get the motor going and then it feels like it slows down again, but it's only in forward a problem, reverse seems to work ok. I was thinking if there is air in the system that needs to be bleeded? But I couldn't find any info for something like that, so that's probably not the problem.
What could it be then, I only changed the o-ring and before it was working fine?
Thanks for any advice.
pj
pj
