Georgia Iron
- Joined
- May 6, 2012
- Messages
- 898
- Location
- USA - Georgia
- Occupation
- Concrete building slab and grading contractor
My 7300 lb cat would sometimes have problems breaking through 3.5 to 4 inch roots or bigger roots. If you use a small 1' bucket it will go through roots better. I picked up stumps that would tip the machine even if you had the blade down and held it as low as you could. I would just bang them against the trailer and let sorta of roll onto the trailer. It would also make poping noises from the chasis when over loaded. A skid steer could not pick up the stump I am talking about another man tried and had to leave it at the job. I would guess the stump was close to 3500 lbs. I did have to de-dirt it before I could even get it to lift.
My 11,000 lbs TB145 Tak. Is one hell of a small machine. Being made as a TB250 now. Seems like ALL the rental companys use tak machines. Just look around they take abuse and put out. It comes with a 2 foot bucket. But I like to run a 1 foot bucket for trees and pipe work. It will pull through any root I can think of. As a matter of fact sometimes if the root wont break it will just pull the hole tree up and over and out of the ground. It is so strong that I have not been around any tree removal that stopped me. I dont dig up 3 and 4 foot diameter tree with it though. Any thing that feels like it could crush me on the machine, I will use a saw on then dig it up.
I think you will be able to clear your drainage ditches with the smaller machine. Just dont get pissed when you lock onto something and the arm pulls the machine foward instead of digging it up. Cause that is normally what happens if the machine runs right....
As far as the zero tail swing. I think it sucks. The machines run rougher and bang you around more. With a normal tail swing the weight is balanced better and you have a bigger cab and it is nicer to sit in all day. But it also sucks when you hit something with the ass end of your machine as you WILL DO. Hopefully it wont be a truck or building cause it really screws them up..... and if you hit the corners with the CAT machines there weak fiberglass tail corners will break all to pieces and they will cost you close to $400 to replace. Even if you tap a Small trees in woods it will ruin them and your machine will start to look bad quick.
The tak has an armored rear end that can take a hit..
