southernman13
Just looking for opinions on repairing this bearing hole. It’s a Steiger tractor that we’re replacing the center pins and hinge pins and bearing,bushings on. This hinge pin hole wa damaged because the outside part of the spherical bearing broke and it was beating around. Kinda hard to tell from the pic but it has a gap on one side of it. I have the new bearing just sitting on top of the hole for reference but it also seems tight enough that I would have to press it in to get it into place. I know the proper way it to have it welded and line bored. Just curious if it would be feasible to put it in and JB weld the gap. Or I could weld the gap and die grind it out or do it the right way and weld and line bore it.
