packratc
Went to the mud pit and got the poor thing to run. Belching white smoke & missing. Took off the valve cover. Kinda suspect one pushrod being slightly bent just by looking. A few of the rocker arms were so loose I could stick a large screwdriver on top of the valve. Didn't have feeler guage so I just snugged them up a little but left them loose. As the hoe was sitting at such a terrible angle I got it to pull itself down in the pond. I was trying to get it to the upper end which is a rock I can stand on. No luck! When the mud on the tire was scrapped of by the fender and pushed against my shin, I left it. As I had the air cleaner off I noticed that there was an intermittent blow back through the intake. Isn't this signs of a burnt intake valve? I don't know nuttin' about no diesel! While it was running and the valve cover off, I lossened the first two cylinders injector lines. Like I was bleeding it. Plenty of fuel but not effect when either one was loosened. Looked to me like it was running on the back two which have the new injectors. If the weather is good tomorrow, I'll get a couple of pallets to set in the mud and set the valves. I'll have to read the manual which is on CD. Seems to me I could get each valve to the top of the cylinder and set them. Any further suggestions and/or comments are hereby solicited as you all have been a great help so far. Thanks, Muddy Packratc in Tennessee.
