nobull1
Charter Member
Well I was wondering if anyone else but me does this stupid stunt.When digging a hole as close as you can to the machine and max depth I find you cannot see the rocks etc at the bottom of the hole.So the only way when by yourself is to stand up lean out the front reach behind and use the joysticks.I am very carefull when doing this but at anytime it could be auto-eject I know it is dangerous but can think of no other way to clean the hole when you have to see exactly what you are doing.Most times you can look, sit, curl, lift but sometimes you have to see as you curl which means head out the front [auto-eject position] Maybe it is just my machine but I would think others must have the same problem
