While using the machine Sunday moving snow, it quit running. When I go to start it, it'll run for like 1/2 a second then die. Every time that is what it does.
It has fuel and I changed both fuel filters after it died. I do not have any manuals, so I checked every fuse and they are all good.
I took the fuel solenoid off and tested it,,,,, it is fine.
Is this a gravity fed fuel system? Is there anything inside the fuel tank,,,,, like a pick up tube???
I took the fuel line coming from the tank to the first filter and held it down expecting fuel to come pouring out,,,,, and nothing. I then put my lips on the tube and blew into it . I could hear bubbles. I then held hose down and fuel starting pouring out, but by the time I got it reconnected to filter, it was just a trickle.
Would I be hurting anything by shooting air up the the hose from a compressor for 1/2 second?
I guess I should be glad it happened at my house instead of elsewhere.....
Thanks for any help,,,,,
