Tinkerer
I think he has it his kitchen.
lol. Yes i do actually ha ha. It’s laminate click flooring but ya it’s kinda too nice for a shop I know. Was the only space I had. It’s a 24x30 “guest house” is hats separate from the house so I covverted it to my workshop. Unfortunately it’s raised about 4ft off the ground on hydro poles so getting engines and heavy things up the ramp to the door is kinda tough. Use what’s available right ...lol. Normally I only repair small engines and atvs etc in there. But it’s a dry place that’s easily heated in the winter for me to work on Things, and it’s all I have till I can afford to build a shop.You have a nice hardwood floor in your shop?
I can get almost 360* crank rotation. I will check the rods and gears for that when holding it against the “blockage”. Expected it to be more obvious since it’s such a sudden and hard stop.never mind, didn't read all the posts
Do you get almost 360 degrees of rotation? or almost two full turns? Can you hold it tight against the 'blockage" with the flywheel and go back to wiggle the rods to see if you can tell if one is tighter? Same with the timing gears, see if there's less play in any of the timing gears when it's held tight to the blockage than when it's loose.
The loose pushrod is suspicious, if that valve is retracted now, and not broken, I still suspect a something was holding it open and dropped into that cylinder now.
If I remove the ink pump with the cover and leave it attached to the cover will it come off and leave the seal in tact? Not sure where I could get the seal and or how to install them if removed. I believe ther s a seal on the inj pump shaft that has to be changed if removed ?? Umbrella seals or something ?I would remove the head for a through look at it and the cylinders. Next would be removing the front cover. I would not be surprised if you have something in stuck in a timing gear.
I will have to look again to be sure but if I remember right. The middle rods were down and the timing marks were at the top left side ( standing behind the flywheel facing the front of the eng). Can’t remember if that was on the “obstruction” or not. I had to put the pan back on to set it down cause I am having some issue getting the engine stand i have to work on this engine. It’s hanging on a small engine crane that settles overnight so I finger tighten the pan on. And set it down. Hope to get a few nights this week to figure out how to mount it to the stand I have and dig a lil deeper into the “ obstruction “. Going to need to get a head gasket kit now too. Shoulda just ordered an in frame kit. It comes with all the gaskets and seals I have bought,along with everything to freshen it up.,and after buying the gaskets and crank seals separate...it’s not that much more to buy a kit ... does anyone recommend for or against a specific kit for the 188? Any I should stay away from or insist on getting ? Thinking my best plan now is to strip it down, clean and inspect it all and rebuild it. Had hoped to be able to just swap and be running. But looks like I might be tearing down two engines, taking the best parts from the pile, adding a rebuild kit to the mix and building one. Hopefully one of the heads is good and won’t need much if any work... this project is killing the budget and keeps getting bigger and bigger lol. Engine swap ends up being a rebuild anyway....:$.Is it stopped at TDC for either pair of pistons? That narrows it down to two to check.
Thanks pump guy. I think I’m going to use the complete head off the orig engine when I rebuild. I believe it will be in better shape and I know it ran well. Can I remove the injection pump from the housing without having to replace the seal ? If it has to be changed do I need any special tools to install it ?Wow.. I never thought it woulda cleaned up like that..
You better take a long look at the tips on the injectors.. IF that crud stopped the engine from turning, chances are, it hit the bottom of the injectors..
IF the holes are collapsed even just "a little bit" it will build up line pressure & seize the injection pump..
Your not gonna be able to see the holes..but if you see that it hit.. replace the injectors..
& with all the expense your incurring.. you dam sure don't need to be buying a $1700.00 injection pump.
