Wes J
There we go! That's what we expected to see. You've got all the marks you need.
I don't think the shuttle has to be timed in any way.
Thanks for that Info. I’m confused a bit now tho..? If I understand right I need to align the flywheel and the other half ( shuttle?) to re assemble it ? I didn’t remove any bolts when i pulled the eng and it separated at the fw as pictured... if I install the fw on the new engine do I need to align it as it says in your post or can I just install it and make sure he teeth mesh together ??? Sorry just wanted to ask. Looks like I need to get access to a CD reading devise and or get my CD manual printed out I know I’ll need it for some torque specs but this alignment sounds critical and is a fairly small tolerance. I didn’t try to pull the part off the tranny side. I did spin it around a couple times thoIf you need more info just ask .
Phew!!! I was worried there for a min that I had some highly technical alignment to do upon installing the engine. Thanks for clearing that up for me. Lol. Going on a hunt for seals and gaskets today. Fingers crossed I can get them locally.The info on the page I posted only refers to the flex plate FF. Nothing technical about sliding the convertor and shuttle into the flywheel. Don't force them together, they will slide together with ease when they are lined up correctly. Cut the heads off of a couple of long bolts and use them for alignment aids.
Ok thanks. I will look at that. I have Valve cover gasket and planned to change it before the swap.Pull the valve cover off and see if a valve is stuck. If it's been sitting a long time, it's very possible.
Funny Farm, Don't panic quite yet like Wes J says pull valve cover and take a look. There is plenty of time to panic latter!Ok thanks. I will look at that. I have Valve cover gasket and planned to change it before the swap.
Hey pumpguy the bolts are offset and should not line up but one way. Now mind you the offset may be slight and can be forced to fit so bear that in mind also. Of course with engine at TDC the timing marks on flywheel should be at top left standing behind engine, if my memory serves me correctly.OK thanks.. I wonder if the bolt holes are "off-set"?? meaning they'll only go on 1 way or 180* out..
Anybody else know??
I have taken the valve cover off , oil pan, front cover over the inj pump gear and the water pump. Nothing obvious stopping the engine from rolling over more than one revolution?... could a lifter be stuck in the block ? Could that explain the one pushrod that was off the rocker when I opened the vc?Pull the valve cover off and see if a valve is stuck. If it's been sitting a long time, it's very possible.
