Another Perkins Pukes
motrack
Charter Member
Ingalls Indiana
field service tech
Steve...... just for ****s and giggles can you see the tag on you engine? I was wondering where that engine was built.
Z'mnypit
South
Any updates on this? Im kinda in the same boat. The oil light starting flashing but no knocking noise's I cut the machine off to check the oil and it was full. Went to start it and its acting like its locked up. It ran maybe 2-3min tops and now nothing
KSSS
Idaho
excavation
I think once that light indicates loss of psi you a seconds to get it shut down before it becomes a boat anchor.
pedahead
roanoke va
I just rebuilt a 3024ct in a 242b that had 6000 hrs .If you do rebuild use the updated head gasket they had problems out of the ones that came in the kit.
John DiMartino
Super Moderator
Walden, NY
Greenskeeper/mechanic
I am sorry for you Steve,and scared for myself,as I have a 246,with the same engine..Im pretty sure the 248 has a 3034T in it,around 74hp net.When researching machines to purchase,I seen several with reman or new engines,and under 2000Hrs.....
watglen
Dunnville, Ontario, Canada
Farmer, drainage and excavating contractor, Farm d
Is there a particular series or model year that is problematic. The 3024 is in many machines, across many years.
Just trying to decide if i should worry or not.
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
I haven't been able to look at it much other than to say nothing has penetrated the block or pan. I'm having issues with my trucks which are more important and my repair time is limited. On top of that we're getting snow every few days which has to be plowed with the trucks that have the repair problems. I'm not a happy camper these days
jrtraderny
New York
Ya , I know I've got a 2010 247B2 that oil sampled @ 100 hrs. with coolant in the oil.
Really wish Cat would dump the Perkins motors in the compact line and go to Yanmar or Kubota.
jr
lynger
Ontario, Canada
Can these skid-steers have a Mitsubishi motor as well? We have a 236B at work and while changing the oil I noticed it said Mitsubishi on a plate on the valve cover. Just wondering if there are different engine options. Ours is around 1400 hrs and nothing yet. Good Luck hopefully Cat will help you out.
jrtraderny
New York
Yeah I believe some of them have Mitsubishi in them.
jr
nzpatch
new zealand
I think the 3.3l 3044 motors are mitsubishis , a four cyl version of the 3046 thats in the d3,4,5 i think, and the 2.2l 3024 are the perkins ones .
the older "A" model ones all had perkins/cat 3034 .am i right?
maquinariawiebe
Down South
Aquisitions
Almost every CAT skidsteer that we receive at our, that have the "Perkapillar" engines, need to be serviced. Lots of times, they have a hole on the side of the block. Considering the value of these skidsteers in our area, and that the engines are hard to replace with a good price. We have to find these skidsteers at a really good price.
derekbroerse
Southern Ontario
With the right parts and some fab skills, you could swap in a Briggs and Stratton if you wanted. ;)
Seriously, its basically an engine driving a pump... I don't see why you couldn't put any engine in there you want.
docjmj
Idaho
Yesterday the second engine failed on my 242b2. 730 hours, the first engine failed at 175 hours this one lasted a bit over 500 hours.
xcmark
Foxboro , Ma.
construction
WTF! I feel for you buddie, I am not trying to throw any punches just would like to know if the oil had been changed more then one or twice? I have a perk in my JCB and this post is not giving me a good feeling .
watglen
Me neither Steve, I think my '05 257b has the 3024. This thread is scaring the crap out of me.
Can you tell me specifically what engine(s) you have failing.
Then can you tell us why do you think?
Thanks
Ken
