Looks like a Sims cab on it. Very clean looking, Hope it gives a lot of good service.
Did you notice it was a two piece door? Once you open the “high” handle, you have to reach over the top of the bottom half of the door and squeeze in the lower inside handle to open the lower half door. That one kind of drops or falls off to the side. First time I‘ve had the two piece doors. I’ve got to get that cab heater working!Never looked that close before but it's weird the door handles are so high. I have a Sims cab off an industrial tractor on my AG tractor. Sims made cabs for a lot of the common brands of industrial tractors and backhoes. I'm not sure if the JD410 cabs were made by Sims though.
I had 1974 410, very different tractor. I've never heard of a 401.The bucket linkage is interesting!
I had a 1981 410 that looked considerably different both with the cab and engine cover so I'm going to guess this is prior to that. The engine cover on yours resembles the ones on the ag tractors, by my vintage the commercial line had its own engine covers.
JD did that so bucket remained level as you raised it.The bucket linkage is interesting!
Yours weighs about half what a 410 weighs. I'd have said it was built on an industrial chassis. A local farmer had a small tractor I feel is the same. His had a loader & was a very convenient machine for hundreds of jobs around the farm.
Very nice looking machine! That beacon light is the bomb. Does it still work?
Looks like you have an 18" bucket and a 30"? Those are nice sizes.
I’ll post a picture tonight. I’m trying to get this cab heater working. So I need to be sure I have the coolant fluid moving. There is a round switch for it that actually has a bulb in it. I have checked to see that the fuse is working by switching it over to the windshield wiper that is working. So I know the fuse is good. I’ll post up a picture of that as well. I get no sound out of fan with switch in any position. This fixing will be done on a very part time basis, unfortunately. They still want me to come in to work to get paidIf it's the kind of valve I think it is, it's closed when all the way in.
If no heat in hoses. Could it just be airlock as well?Easy way to tell, are the hoses hot?
Heater cores tend to get plugged if anti freeze isn't changed often enough. I've had to take them along with the radiator to a shop boils them out with acid.
Have you opened the valve?If no heat in hoses. Could it just be airlock as well?
No time yet. Just got home from work and I’m beat. Going to have to wait. I think I had it open before. But will probably check it out Friday. Working 12 hours tomorrow too, and they say we have 3-6” of snow coming Thursday afternoon to Friday afternoon. Yeah! Wait. NOT!Have you opened the valve?
That beacon light works! LOL I still forgot to measure the buckets.
I'd be using that thing all the time. LOL Someone really took care of that machine it appears. Hoping you get a ton of work out of it!
owned by a Township in Northeast PA
