mdgibbs31085
I’m in desperate need of some advice. I have an Allis Chalmers HD6E dozer with an Auburn Style over-center clutch. Last summer I replaced the clutch plate and the 6 links on the engaging body. I also removed the slop from the clutch lever linkages. After adjusting the clutch to 30 lbs of pressure (the manual states 25 to 30 lbs), the dozer pushed like a new machine. Just one problem…after 4 to 6 hours, I find myself having to readjust the clutch. Talk about frustrating. I’ve probably only put 30 hours on the new clutch and have adjusted it 5 times. At first I thought the adjusting ring was backing off, but that’s not the case.
Any suggestions would be much appreciated. Thank you!
