The line temp would be measured after the condenser. There will be lines going into/out of the receiver. That is a good place to gather the temps. I prefer after the receiver as it gets me real world data going to the TXV.
if you reference my image, you will see my line temp was about 126F, and ambient was 100F. Do NOT test with a stupid IR gun. You need a good thermocouple ziptied to the liquid line. You would read the temp at the same time as the pressure. Subcool can then be calculated from there.
I did the tests. I checked the readings every 5 minutes or so. I'll give you some of the data and if you need more I might have it. Unfortunately I can't say that I'm 100% sure about the liquid line temps. I got almost the same readings from a very good digital meat thermometer and I used an infrared too just to compare. Either way, it was warm to the touch at the drier but not hot. Highest reading I got was 110. After re-reading what you said, I thought that I was supposed to check after the drier where there isn't any room to hook up a probe. I think you're saying that it can be before the drier. I can try again tomorrow.
Both the low and high pressures generally varied by a few psi every few seconds each cycle so I am giving the middle numbers.
At startup the outside temp was 93 and it was 139 inside the machine.
For the first couple of minutes, the low pressure was about 28psi and high was about 200psi.
After 15 minutes the low was 21psi, high 178psi, vent temp 54, liquid line 110
After about 18 minutes the compressor turned off for the first time. After that it cycled every minute or so.
After 25 minutes low 20psi, high 175 psi, vent 55, liq line 109
After 45 minutes low 19psi, high 163 psi, vent 50-but quickly went up to 58 while cycling, liq line 108.
There was very little water dripping out of the 2 drains that I can see. There is 1 drain that I can't see. The one that still has the valve on it drips about every 14 seconds. I did not see any water coming out of the drain with the missing valve until I turned off the blower and a lot of water came out immediately. Also, by the end there was water coming out of a couple of the vents again. Hope all of this means something and let me know if I need to do some more tests.
Thanks
