- Joined
- Jan 21, 2007
- Messages
- 13,413
- Location
- Alabama
- Occupation
- Running what I brung and taking what I win
Hence the C for "compact" track loader in CTL, maybe? :beatsme
Haha, smart ass.:tong
Kinda...but these dang rubber tracks and loading trucks while looking through the roof leave something to be desired.
I have been harping on the true costs of CTL's in relation to the undercarriage per hour true cost.
Case in point -
Had to buy a rubber track a week or so ago for the T250, $1100. 2 rear rollers $300 each.
My Cat PSR quoted new pads and bolts/nuts for the D5G. $2700.
If I were to replace both tracks on the T250 would be $2200. $2700 to replace the pads and hardware on the D5G, $500 difference. No other undercarriage components are included on either machine. Now this doesn't take into consideration the track chains on the D5 as a new rubber track includes it's "chain".
However, look at the difference in hours one gets between the two. A rubber track will last (hopefully - I have seen these numbers in the past) 500-600 hours, although I have had very bad luck with rubber tracks over the last 3 years, going through 7 on the T250. No change in the operating environment or the types of jobs it does. The problem we have been having is breaking the cords, where the T-bone starts to bulge and creates a knot on the outside of the track. When this happens, just run it to failure as the track is toast.
$2200 for two tracks for the T250 and assume 500 hours, that's $4.40 per hour. It's been a while since I could get 500 hours out of a track but I have in the past. In reality, went through 7 tracks on the T250 in 500 hours. Now 2 of those tracks were old and worn so they can be taken out of the equation for an accurate comparison. That still leaves 5 tracks in 500 hours at a cost of $1100 a piece, $5500 total cost and $11 per hour of operation just for tracks.
I had the undercarriage measured by the PSR on the D5 a couple of weeks ago. Most worn component was the left track side at 62%, that's at 4400 hours.
For the sake of comparison, let's say the D5 gets another 2000 hours out of the total undercarriage before the most worn component the chains, need to be replaced. Estimates to replace the entire UC on the D5 is in the $15000 range. That's roughly $2.35 per hour - $15K/6400 hours. Now the pads on the D5 need to be replaced at the moment so add another $2700 to $15k for a total of $17,700, as this cost needs to be accounted for and assuming the pads replaced now would be worn out at 6400 hours - the $15k includes pads at the time of total replacement. That would bring the hourly operating cost to $2.77 per hour.
Now I have replaced the pads twice on this machine already and I don't remember the actual cost but let's assume it was $2700 each time. That's an additional $5400. Add the $5400 to the $17,700 which is $23,100 divide by 6400 hours - $3.61 per hour.
Neither cost comparison includes labor to R&R, it's materials only. So in closing my actual costs for undercarriage between the two machines so far is $4 an hour for the D5 and $11 for the T250. This is still not an accurate comparison as I didn't include the other components of the undercarriage on the T250 that will need to be replaced some time in the future but gives one an idea of the true costs of a CTL. If we can achieve historical numbers on the life of a CTL track (500 hours and not this machine) then the operating costs between the D5 and T250 are comparable, however the past 3 years have proved otherwise.
I just want to let people know of the true costs involved in running a CTL. I love the T250 and goes to almost every job, as it's handy as a shirt pocket but one has to analyze the true operating costs of every piece of iron you own.
