DrBobD
I have done automotive A/C for some time now but have started a business doing mobile work on heavy equipment. Approximately 70% of the time there is no tag showing the proper weight of refrigerant required. About 20% of those units have a sight glass which helps resolve the problem on those, to some extent. In some cases I am doing the work for a dealer who supplies me with the information.
My problem is with about 30% of the units that I work on. I have been charging to a high side pressure of about 225 psi on a hot day and around 200 when it is a little milder. I know an over charge is going to show high pressures, there is a the possibility that some of these units may be under charged. Most of us know that an under charge will affect oil flow and can be very damaging to compressor.
Here's my question, is there a better way to charge a system if you could not get the proper information on gauge readings or quantity of refrigerant specified by the manufacture?
I have been told by someone in the past to keep adding a quarter pound at a time until the high side gauge spikes and then remove a quarter pound. The problem is I have never seen the high gauge spike unless the fan is not working.
Any advice is much appreciated.
