With the machine dating from 2007 the piston seals being hardened with age and having taken a set is entirely possible. I'd imagine the accumulators have never been resealed before.
Hi we are facing similar problem , based on last thread we shall check brake accumulator today , can you confirm your problem was permanently resolved with this fix. We have so far changed - Pilot pump , Implement control solenoid , all 4 cartridges , but pilot pressure suddenly becomes zero. We have been struggling for months with this .The inside accumulator had 0psi and the outside one had about 400psi. Charged them both to 800 and everything seems to be working fine now. I guess time will tell if they hold their charges
As far as I know re-sealing and charging the accumulators fixed the problem.can you confirm your problem was permanently resolved with this fix.
