973c codes
farmerlund
North Dakota
Farmer/ excavator
So on initial start up when it’s cold out, 15-20*F. I get a couple codes. Also the transmission caution light comes on. After moving back and forth getting it warmed up a little they go away. Can work all day. If I shut it off it starts all over again.
Ser#3RZ00801
Local deal says it a sensor low voltage warning that comes under 23V. When I check before I start it it’s 25 V. Running it’s 27V.
they called it overload sensor? But didn’t know where it’s located. Any help is appreciated.
1EF1586E-134A-4269-BE73-6B73D9C6DD48.jpeg1EF1586E-134A-4269-BE73-6B73D9C6DD48.jpeg77386625-231D-444D-9146-20E07E7F0D66.jpeg54D96F68-2062-4C90-AB42-2FF39396229F.jpeg
They don't know their a$$ from their elbow. It's a Code for the electrical system voltage.
See attached troubleshooting procedure. It may be some sort of issue between the power source (batteries) and the ECM when the engine is stopped.
EDIT: Sorry didn't see your last photo. At first blush they all looked the same. Also attached troubleshooting for 132-04. I'll send you an electrical schematic that shows the location of the override pressure sensor.
  • MID079 CID0168 FMI04.pdf
  • MID079 CID0132 FMI04.pdf
farmerlund
North Dakota
Farmer/ excavator
Thanks Nige,
I will see if I can get it figured. So the override sensor is located close to the ECM for the hydrostacic trans?
Edit: I found your DM. Thank
farmerlund
North Dakota
Farmer/ excavator
So I believe this is the sensor. It doesn’t seam to unplug from the large cylinder that it’s wired to. But I can unplug the two of them.
farmerlund
North Dakota
Farmer/ excavator
4337AE91-9F05-450D-B2AD-14FE22D4AE06.jpeg8881C171-E073-4A1C-864A-6DC31A478ED2.jpeg90C06CE0-F87A-4BE5-AF0C-217CECF23F1C.jpegSo tested the power at the triangle 3 prong plug. 24.5v sitting, 27.5v running. Also discovered this little rub mark on the wires. It seams to be better with the wires not zip tied to valve body.
farmerlund
North Dakota
Farmer/ excavator
Does someone have instructions for clearing stored codes? Mine has the 3 switches in the right armrest. Also when I unplugged the connection I got another code. 079-0132.03
farmerlund
North Dakota
Farmer/ excavator
Thanks Nige for your help. I forgot about the click box thread. Plus thanks again for the wire Schematics I would never figure it out without finding that sensor.
farmerlund
North Dakota
Farmer/ excavator
I am 90% sure it was this wire rubbed through touching the corner of the valve body. It’s the white power from battery wire. Once I cut the zip ties for plug I noticed it was chafed.
Ya I know it’s a terrible picture. lol 1FAF0B9C-F494-449C-93FC-055A01CE6F32.jpeg
But why would the sensor only act up when the engine is cold.? Surely whenever vibration put that bare conductor into contact with the valve cover then it should throw the 132-04 Code irrespective of the engine coolant temperature. Doesn’t make complete sense to me.
farmerlund
North Dakota
Farmer/ excavator
I totally agree with you. maybe when it sits overnight at 15-20 degrees F, the zip ties, wire or something shrinks a little allowing it to make contact, warmes up and moves a little? it was just barely rubbed through the insulation. like a pin hole at one strand of wire. not really sure why the temp affects it. Its a really sharp 90* corner it was against.
I have a couple little jobs to do the next few days. We will see if its cured. My other thought is, that the sensor itself is somehow affected by the temp change?
I really hate intermittant electrical problems.
Shouldn’t be.
That 3-pin connector can be disassembled and the pins removed if you pull the small orange or green thingamibob from the centre. There are small little plastic fingers that can be lifted to allow each pin to be pulled out. A bit of contact cleaner and slide a short length of shrink insulation over the wires. Reassemble the wires into the connector (making sure the pins go back in the correct holes) slide the shrink over the wires and hit it with some heat.
farmerlund
North Dakota
Farmer/ excavator
So here is todays report. Started it this am after it was 15* F last night. Light was on right away for the
132-04 code. When I move the direction lever out of park the code goes away. Does'nt matter what engine speed or how warm the machine is. I used it for 4-5hrs. Still is the same. only get active code with lever in park.
So it is better. Don't get the 168-04 code at all. I Have the unplug test to do tomorrow, but I am pretty sure the sensor is failing. It has 27V at the sensor when I test it.
