OHHH, so the hydraulic hose should come with the flange assembly already attatched?Aaaah! What you've got there my friend is a genuine bodge. Someone has cut the end off the original hose and brazed on a JIC nipple.
Now, how can I find the part number for that?
Ken, you know me, I will rarely comment without a serial number but in this case, I'm familiar with that particular hose and I'm confident it's the red one we're talking about.
I appreciate everyones help. You can tell im a novice. Some old paper work i have on hand says SN 6z1409, the loader is 50 miles away. I can check the cat then. It is the red hose.I understand Cmark, you have much more knowledge of these that I did not mean to step on your toes in anyway.
That said I try to take every chance I get to drive home the importance of a S/N and sometimes even that is not enough at least with older machines you can get into the problem of someone making a change after it left the factory. Like someone making one machine out of two or three out in the bush!
Sometimes steel toe hip boots might be a good choice!Absolutley no offence taken mate. And anyway, I always put my safety boots on before coming on here
What confused me was one end of the hose was removed like a normal hydraulic hose, the other end would not budge and I had to remove the flange held on with the two 3\8s bolts. Put it in a vise and it still would not come off, now i get that its a customI aftermarket 1 of a kind. I will get the SN tomorrow and use the 3G6885 part number. thanks again for everyones time!A part number for what? The complete hose is 3G6885 and as I mentioned several posts ago, the flange part number can be found in HIS which I don't have. Or try giving some dimensions, we may be able to track it down from those.
There was the same adapter on each end of the hose that was held on with 2 bolts, one end i left the adapter attached and just removed the hydraulic hose, the other end was stuck and had to remove adapter still attached to hose. As pointed out this was a home made solution by previous owner. I assume the new hose will not have removable adapters and be all one piece.6z1409 is the unit serial number, and, that hose is same for all transmission s/n in that tractor.
I have to wonder why the hose picture posted doesn't have the adapter shown, too. Clearly, it won't be used with the Caterpillar part numbered hose.
