96 case 1840 drive motor removal?
Mattc
Missouri
Trying to remove the rh drive motor and I am running into an issue where the two feed lines go in. The top 45* fitting sits immediately over the lower and doesn’t allow access to the lower line nut. The upper fitting doesn’t have room to come out because of the lower line. Is there a trick to this. Is there a trick to this? Or am I blatantly missing something.
Vetech63
Oklahoma
Loosen the jam nut on the fitting that the hose is attached to. It should give you a bit of room to maneuver around by pushing or pulling on the hose. An angle wrench is your friend on a lot of stuff like this.
Mattc
Missouri
I’ll give that a try.
