Trying to remove the rh drive motor and I am running into an issue where the two feed lines go in. The top 45* fitting sits immediately over the lower and doesn’t allow access to the lower line nut. The upper fitting doesn’t have room to come out because of the lower line. Is there a trick to this. Is there a trick to this? Or am I blatantly missing something.
