Charlie
I have been digging like crazy since I put it all back together. The swing is nice and tight - like it was when it was new. I have been stumping with it for about a week and am going to start digging a foundation next week. The new planetary gears are so precise and tight that during the winter i wasn't able to swing all the way around- it would only go about 90 degrees to either side and then wasn't able to go any more. I am assuming it was because the ring gear shrunk do to freezing temps and there wasn't enough lash in the gears to allow it go. But before winter it worked fine, and now that it has warmed up above freezing(mostly) it works fine again. I think with a little wear on those gears, this issue should go away. Its not really a big deal for me anyway, since I don't really use it much in the deep winter. Charlie, I can't thank you enough for sending along the manual for the swing device, there is no way I would have ever been able to get the part numbers for the bearings, seals, and gaskets at the bottom without it. Thanks to you I am back in business - thanks again. Happy diggin'
Rush
Does anyone here know where to get swing drive unit assy (hydraulic motor + gear reducer + pinion) for ex50urg?
