ms0115
Wondering if there were any Detroit diesel mechanics out there that would let me ask some questions about problems that I am having with a 8V92 Industrial .
Thanks
Thanks
Was the original setting 1.460? I don't know much about the industrial 92s, but most industrial V-71s run a 1.460 setting with standard cam timing and 1.484 makes them run like a dog.
The 1.484 is for advanced timed engines; usually turbos. It goes with having the idler gear advanced one tooth. The higher the injector is set, the sooner the rocker arm will depress it.
I am pretty sure there is a model and serial number on the block. Look for a flat machined spot; maybe above the oil cooler or on the top of the block behind the blower near the front of the flywheel housing.
A couple of things to check. Put a small screw driver in the rocker and injector arms and wiggle to check the bushing wear. If there is any play, they are shot. Make sure the valves are set right. Another more advanced check is to pull an air box cover then rotate the engine until the rings are visible. You should notice an indented line in the compression rings. If not, they are worn out. I don't really recommend this check because the air box gaskets can be stubborn to clean up and they are in nasty places too.
As always, clean fuel filters, make sure the engine is getting fuel and no plugged intake lines, and make sure it is getting all the air it needs, so clean air filters and few bends in the intake piping. Good luck.
First off, there are no numbers on the block. It was factory remaned. at one point. The tag was riveted to the block, still have rivets do not have tag. The company found some old paper work from DD that said the serial # 8FF5093 model # 8083 7400. The turbo had been replaced do to seal failure and made a mess of air flow through the cooler. I replaced the cooler, I have checked the piston rings and they looked good. ( Around 1,000 hours on a rebuild, then set for 2 years prior to coming to my shop for lack of power. Earlier I said the injectors ran out of stroke, I would like to clarify this statement). Valves down, injector up, set the injector to 1.484, rotate motor, when that injector is depressed, the motor will not turn through (bottoming out injector). Go to 1.600, the motor cranks and runs, ton of black smoke and does not want to achieve top rpm. I pulled the injectors today, 3 would not spray properly. This still does not explain not being able to set the timing according the book. Thanks for the help. Forgot to mention, they ran 9G85 injectors in this motor for years. When it started running low in power someone sold them on putting the 9290 injectors in. In this application, which should I go with?
Valves down, injector up, set the injector to 1.484, rotate motor, when that injector is depressed, the motor will not turn through (bottoming out injector). Go to 1.600, the motor cranks and runs, ton of black smoke and does not want to achieve top rpm. .
