621B drive problem
ServiceRoutier
Saint-Jérome,Québec
Hello,I have a 621B,the transmission does not work on the 1 and 2nd gear...it wants to go in but doesn't go...what could be the problem? the 3 and 4th gear grips very well. Please write back by email on July_ju18@hotmail.com because i'm from Montréal,Québec. Thank you for your attention Claude-
Marro13
Long Island
Did you ever find a solution I'm having a similar problem but when my machine is on now I'm getting 10 large bang from the lines out of the brake vales assembly . So I took the valve apart everything seems good checked poppet valves and screen. break light warning comes on and off randomly
Coy Lancaster
Arkansas
service tech
Your transmission is in what's called limp home mode. I would check your speed sensors in the side of the transmission case. There is a turbine speed sensor and a gear speed sensor, they are the same prt# . There are shims that fit on the threaded end of sensor so be sure and reuse them.
Have a '91 621 that tranny slips in 3rd and 4th. 1st and 2nd are fine. Any ideas?
I would check your pressure and the control solenoids on trans control valve.
