60 series fuel shutoff
BigfootBill
Utah
Looking for location of electric fuel shutoff on 60 series with manual injectors. Any thoughts?
RZucker
Wherever I end up
Mechanic/welder
60 series with "manual" injectors? You have something confused here. The 60 series engines had electronic injectors that were on or off to control fuel flow.
The older 2 stroke Detroits and the 8.2L engines had mechanical governors and fuel racks that controlled the injectors, some of those had electric solenoids to let the engine run or shutdown.
BigfootBill
Utah
Now that u mention it, I’m sure you’re right. I’m talking someone else through this over phone. Thanks
Shimmy1
North Dakota
If a 60 series won't start, first place to look is at all the grounds. Batteries, frame, engine, all of them. Of course, this is after you make sure there is fuel in the tank, lol.
RZucker
Wherever I end up
Mechanic/welder
Also check the 2 fuses that feed the ECM, some are in the battery box, some are elsewhere depending on the truck manufacturer.
And that check valve comes in several ranges make sure the correct one is installed. The trouble with a thread that has no info from the op like this one. It's assumed it won't start.
There is also manual fuel shut off on the primary filter head. Crank position sensor, injector harness and rail pump are some common problem areas plus the ecm could have taken
a dump.
Bluox
WA state
Actually series 60 injectors are mechanical unit injectors electronic controlled .
the later 71 and 92 motors used a electronic fuel control on a mechanical unit injector ,no rack or governor but both use a camshaft and rocker to manually inject fuel.
Yes 92.. its on the back of the head.. looks like a regular old brass outlet fitting.. but has a check valve in it..
The restrictor fitting doesn't have a check valve in it but if the motor had one it would be screwed on the fitting or on the other end of the fuel return line.
Bob
  • Like
Reactions: DB2
RZucker
Wherever I end up
Mechanic/welder
Bob
I am quite familiar with the DDEC system on both the late 2 strokes and the Series 60 engines. Was merely stating there is no shutdown solenoid valve such as the one Cummins used on their engines.
Oh yes that is a check valve at the back of the head, it can be disassembled and there is a aluminum piece with a ball and spring. The aluminum piece will deform and or can
cause extended cranking or a complete no start. It will start with ether and once running stay running but shut off for more than fifteen minutes and it will probably not start.
RZucker
Wherever I end up
Mechanic/welder
ECM lost power, broken wire inside harness. Thanks for thoughts
Good to hear you found it. I spent Monday chasing an overheat shutdown on one. Showed a high coolant temp code, turned out to be a shorted wire on the OIL temp sensor. Apparently oil and Coolant high temp are the same thing to this engine. :rolleyes:
